starting problems
Old Jan 31, 2009 | 02:21 AM
LTVans's Avatar
if someone can point me in the right direction i would appreciate it i got a 93 legendand in the morning it doesn't wanna start enless i put my hand over the intake hose and choke out the system but once i get it started the restof the day it will start up just fine untill the next morning any suggestions would be helpful for i do not have time or money to take it to a technican thank you
Old Jan 31, 2009 | 03:57 PM
next time it is hard to start floor the gas. that should tell the ecm to do a clear flood and will cut off its fuel.
also try turning the key on for 10 seconds with out starting then turn it off for 10 more... then try to start it. (if that makes it go vroom then focus on fuel system pressures and down time bleeding)
another note...when was its last tuneup?
Edited by: acuralegend
Old Feb 1, 2009 | 01:56 AM
LTVans's Avatar
i already triedbothwith the gas pedal andkeyand the tune up was just done new plugs ,fuel filter, air filter, valve cover gaskets, throttle body cleaning, and fuel injection cleaners added
Old Feb 2, 2009 | 09:57 AM
did this issue start right after the tune up?
like the firing order was mixed up.
or the wrong gap on them plugs?
a hose got disturbed and unplugged?
look at the fuel pressure regulater vacume hose.
Old Feb 3, 2009 | 12:28 PM
LTVans's Avatar
no it was like that before i even got the car, but my cousin turn me on to the lucas fuel injection cleaner so i put it in last night and drove around for 100 miles and the car stated right up in the morning so makes me think that the injector where clogged or something but i'll seeif it starts up tomarrow thanks for the help though
Old Feb 4, 2009 | 05:37 PM
stdvd's Avatar
may be you must check the battery cable or maybe the engine still cold so the engine is hard to start
Old Feb 11, 2009 | 04:08 PM
LTVans's Avatar
got her running just perfectly thanks anyway for the help
Old Feb 18, 2009 | 11:32 PM
freecarforum's Avatar
you need to tell the ecm to do a clear flood and will cut off its fuel. that might help you.
new cars
Andrew Hawk
Oct 7, 2012 02:46 PM
Papawill6
Dec 18, 2010 11:44 PM
greenmoneypit
Aug 30, 2007 11:32 PM
duane
Mar 27, 2007 06:12 PM
purelypoetry
Sep 17, 2006 04:02 PM
