'95 integra ls "problem starting"
I have a automatic '95 integra ls with a start up problem. the engine cranks, but does not start. when it finally starts (after appox. 5min), i can smell a strong odor of gasoline. car drives excellent once engine has started. i only have this issue when the car has been running and engine is hot. i have replaced the fuel filter, distributor, and spark plugs and still have this issue. the fuel pump and relay appears to be working fine. any information i obtain will be greatly appreciated. thanks.
Here are some things I would suggest that you need to check:
- Battery Corrosion
- Dead Battery
- Bad Ignition Switch
- Coil Testing
- Distributor Cap
- Fuel Pump and Relay
- Fuel Filter
- Loose Starter
- Faulty Cold Start Valve
This site may help you:
_______________
We Continue to Fight for Your TV Show One Tree Hill Seasons 1-9 DVD Dreams
_______________
