92 Integra dies wile driving
Old Apr 9, 2008 | 01:53 PM
snowraver1's Avatar
Hey Guys,
I'm new here and don't really know a lot about cars so was hoping that I would be able to get some expert advice.
Occationally my car will die when I am driving it. Over the last 4 days it has done this 4 times. I am unable to see and condition similarities:
1 -Driving on the highway (110 km/h)Temp close to freezing
2 - Driving to work (60 - 70 km/h) Temp close to freezing
3- Driving to work (20-30 km/h) About +5 celcius
4 - Getting lunch (40km/h) about +7 degrees
When the car dies, there is no sputtering, it's a clean death. When the car dies, the tach drops to 0, the temp indicator slowly falls (just like when you turn off the car), I think that the spedometer still works, the engine light is NOT lit, the turn indicators do not work, the radio is working.
I can start the car up without a problem (knock on wood). The first time, the car started on it's own (likely due to the speed andthe engine still being in gear (Automatic)) The other times I put the trans into N and started her back up. She starts fine, and sounds normal when running.
If anyone has any ideas, please let me know. I'm taking it into the dealer tomorrow, but I don't want to replace something if it's not the right part.
Thanks guys!!
Old Apr 10, 2008 | 08:36 AM
jmitch99's Avatar
I had the same problem. It was the main relay. The main relay has three circuits, one powers ignition, one powers fuel pump and other for fuel injection. I removed the relay, popped it open and cleaned all of the contacts oryou could just buy a new one. It is located in the dashboard near the steering column. There are other relays there, so I would advise using a manual with an electrical drawing to make sure that you find the right one. Good luck.
Old Apr 10, 2008 | 10:29 PM
snowraver1's Avatar
Thanks Mitch, from my research on the Internet, that seems like a likely cause. It's at the dealer right now... I'll post the results.
RE2
Aug 10, 2012 07:18 AM
KAkidd
Sep 11, 2008 06:05 AM
weholm
Jun 13, 2008 11:01 PM
mikesand
Oct 29, 2007 05:36 PM
tha5150
Oct 2, 2007 07:23 AM
