2007 rdx multiple issues
Old May 21, 2026 | 05:06 PM
BIKEBUILDERPA's Avatar
Default 2007 rdx multiple issues
2007 acura rdx replaced oil pressure solenoid, brake master cylinder now vsa, check brakes codes, 2647 appear. I had a valve cover leak above the Oil pressure solenoid which was repaired. Brake master cylinder replaced and removed 3x last time noticed seal on shaft was torn. Replaced that. Oil pressure solenoid was replaced and connector was also replaced. Drove it home from garage, about 5 miles and today drove around the block. Two blocks away same three codes. Also got emissions code but that went away as I pulled in garage. Anyone have issues like this? Garage mentioned that during diagnostic a lot of different sensors for wheels and brakes were reading as bad, but common sense was this can not happen suddenly.
Fishheadbarandgrill
Aug 1, 2024 09:37 PM
Soarer
Nov 26, 2023 11:24 AM
Flyboy
Jul 23, 2022 10:08 AM
BruceRD
Jan 31, 2022 08:12 AM
nova
Nov 8, 2021 09:35 AM
