Dash lights intermittant
Old Jan 11, 2008 | 01:55 PM
arslws's Avatar
98 RL SE 57000 miles.
&lt; src="http://www.google-analytics.com/urchin.js" =text/&gt; </>The other day, one of my dash lights went out. I was preparing to tear into the dash to replace the bulb, when I happened accross the Honda Odyssey forum. They are notorius for having lights go out. Most people were able to restore the lights with a firm tap on the dashboard. (Firm, not put your fist thru it). I tried it and after the second tap, the light came back on.
Before you pay the dealer to do this for you, try it a couple of times. It might save you a $100 bill.[img]smileys/smiley2.gif[/img] &lt; =text/&gt; _uacct = "UA-939292-41"; urchinTracker(); </>
</>Edited by: arslws
Old Jan 12, 2008 | 05:29 AM
sounds like the dimmer switch is going bad< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
Old Jan 12, 2008 | 09:08 AM
arslws's Avatar
I dont think the dimmer switch is involved. There was only 1 light bulb out.[img]smileys/smiley14.gif[/img]
Old Jan 16, 2008 | 04:57 PM
antoinewilson22's Avatar
Instrument cluster?
Old Feb 24, 2008 | 02:07 AM
RL_Legend's Avatar
Thats usually the first thing i do, tap or hit it to see if it works. Sadly, this time I know its out, but what I don't know is before I take my dash apart can i replace the bulbs or do i have to replace the cluster on my 99 acura RL. If I can change the blubs will the color ones show through or is the gagues colored already.
Old Feb 25, 2008 | 09:10 AM
arslws's Avatar
Old Feb 25, 2008 | 09:14 AM
arslws's Avatar
I assume that the dash panel is similar to the one on my Honda Odyssey. There are several small bulbs in the Ody that are replaceable after you tear the dash apart. Go to the Odyssey Forum and see the instructions and descriptions for dash light replacement. there is a lot more information than on the Acura forum. The procedure is a little different, but I think that the engineering is similar. Good luck. Post your results here when you fix your problem
ercen halycon
Oct 19, 2012 10:33 PM
AcuraDoug
Jan 11, 2012 11:04 PM
tejadasammy
Nov 25, 2008 09:33 PM
miked8887
Sep 17, 2008 10:17 PM
Acura Ray
May 28, 2008 08:52 PM
