Clunk and lunge forward when shifting into drive from park, reverse, or neutral
Old Aug 13, 2024 | 11:52 AM
Kurt87's Avatar
Default Clunk and lunge forward when shifting into drive from park, reverse, or neutral
Hello,
I own a 2010 acura rdx with 177 xxx kilometers.
When I shift into drive from either park, neutral, or reverse and car makes a clunk and violently lunges forward. Watched the engine while someone changed it to drive and it moved about 2 inches.
Not noticing anything too alarming when I'm driving. There is a slight, slight, slight lunge forward when it shifts gears.
Just wondering what this could be, thanks in advance!
Old Oct 3, 2024 | 08:53 PM
Acuraboy's Avatar
When your car lunges forward does the engine rpm jump?
Old Oct 4, 2024 | 10:24 AM
John from PA's Avatar
2010...might need new motor mounts. While observing the engine movement, have someone put the car into gear WHILE THEY HAVE THE BRAKE PEDAL DEPRESSED. There should only be slight movement of the engine.
kehock
Mar 27, 2024 09:49 AM
krish727
Jan 12, 2016 11:40 PM
antoinewilson22
Sep 24, 2008 11:16 AM
lionj
Jul 17, 2008 12:57 PM
