overheating
Old Apr 26, 2008 | 09:05 PM
iceman77's Avatar
</>I have a 93 integra. If the car just sits it will start to overheat. I took the thermastat out b/c I thought maybe it was stuck but it still overheats. Does anyone have any ideas?
TJ
Old Apr 29, 2008 | 10:51 PM
jmitch99's Avatar
If it is just sitting, the fans need to come on when it gets hot. If the fans are coming on, then I would check to see that there is circulation in the radiator. Take the cap off, start the engine, look into the raditor while revving the motor. You should be able to see the water moving. There is also an air bleeder no the thermostat housing. make sure you are not air bound.
Old Apr 30, 2008 | 08:38 PM
iceman77's Avatar
Thanks man.
Old May 1, 2008 | 01:49 PM
take it to a few shops and have a combustable leak test performed tyo make sure that head is tight and not leaking
if yes then get a second opinion
Old May 2, 2008 | 10:34 PM
iceman77's Avatar
aloright. thanks for advice.
sks19.del
Jun 25, 2008 04:13 PM
Sammy
Oct 29, 2007 08:49 PM
bfagrell
Sep 17, 2007 12:13 PM
rzvr6
Aug 27, 2007 07:22 PM
rzvr6
Dec 16, 2005 01:56 PM
