Mechanical issue Weak Cranking
Old Jan 9, 2008 | 01:06 PM
88integraLS's Avatar
So my car wouldn't start very well in the rain. I replaced the spark plug cables, plugs, distributor cap, and rotor. It worked flawlesly for a day, then the next day (another wet day) it started no problems, went about 300 metres from my house and the enginejust died (check engine light came on at the same time as I was pulling my car over to the side of the road in neutral).
Now when I go to crank it, it's a strong enough cranking (so I'm positive it's not the battery) but yet sounds weak, if that makes any sense. Meaning it sounds like "whirring", but no "chugga chugga"?!?!
IS that the sound of a fried ignition coil? ignitor? Again I doubt it's to do with the starter motor as the problem occured while driving.
Any help would be MUCH appreciated.
Old Jan 10, 2008 | 07:55 AM
i would be suspect of that distrubiter and/or 1 of its seals
if that cap gets wet you will not get spark where it needs to go.
when you try to restart the engine do you still have that check engine light or did it go out?
if the light is on then look under the pass seat and count the flashes to pull up the indicated code.
if a puddle is all it take to wash out your ignition system. check to see if the splash panel is under the front of the car, if its missing find 1 and reinstall it.
did the gasket go back in between the cap and the distrubiter?
are your spark plug tubes filling with water?
&lt; src="http://www.google-analytics.com/urchin.js" ="text/"&gt;&lt; ="text/"&gt;_uacct = "UA-939292-41";
< ="text/">
Edited by: acuralegend
x_saturn_x3
Sep 4, 2007 11:17 PM
lexicon66
Apr 14, 2007 11:38 PM
Acura74
Dec 7, 2006 07:03 PM
justin96
Nov 28, 2006 02:12 AM
jetskiman123
May 15, 2006 04:09 PM
