Error Code P1362--Distributor vs Camshaft
Old Sep 29, 2007 | 06:16 PM
homemehanic's Avatar
Hi All,
Need a little help. Got a check engine light code of P1362. It's pointing to faulty/no signal Camshaft Position (CMP) Sensor or Top Dead Center (TDC) sensor.
I saw two mechanics. One was thinking its the distributor and the other is thinking the Camshaft sensor. Which one do you think? Are they ways to actually test the distributor?
I hate to go buy a distributor, install it, find out that the distributor is OK and can't return the new distributor.
Thanks guys!
Old Oct 2, 2007 | 07:31 AM
ok first what is and what year is this vehicle.
and both of your techs are right IMO
the distrubiter houses the cam position sensor
and honda/acuras are well known to eat distributors
its a 300 BUCK BET but im betting on the dist being bad
Dave at my shop may have a used for you. 1800-767-8640 (Scott,s )
If not i know we can get New cheeper than the dealer and our new ones are complete with cap and rotor. (please dont take a reman) i have has such bad luck with those...like buying 3-4 befor 1 actually works. then it only works for a month or 2...the new ones come with a warranty (ours has a 1 year)
Old Oct 3, 2007 | 12:07 AM
Thanks!
99 Integra LS. . DOHC engine
By the way, how do you install the distributor correctly? Some said I need to reset the timing. Another person said I just turn the rotor in the good distributor to match up with the bad distributor.
Any help will be appreciated!
Thanks again!
Old Jun 3, 2011 | 04:59 AM
ndrewoods's Avatar
Originally Posted by homemehanic
Thanks!
Thanks again!
Bump. When installing a distributor, better make sure you also install the distributor clamp properly. Or you would be having a hard time fixing the cap and the rotor as well.
Old Jun 8, 2011 | 02:00 AM
Good point there...
ndrewoods
Jun 13, 2011 04:40 PM
hd_sporty
Oct 20, 2008 11:16 PM
cat52
Sep 11, 2007 06:28 PM
matthekc
Sep 6, 2007 06:57 PM
glxjunkie
Feb 21, 2006 05:26 PM
