RPM goes up & down at idle
Old Mar 10, 2009 | 09:01 AM
M E  Berg's Avatar
Help, any ideas Acura owners. 1998 acura integra GSR ,
The RPMgoes up from 800 to 2000 then drops down then repeats the same symptom over and over again at idle.
Thanks Matt
Old Mar 10, 2009 | 10:27 AM
L3GDKANG/JDM-KA's Avatar
have you replace the idle control valve and als check for vac leaks!
Old Mar 28, 2009 | 04:19 PM
AKinDen's Avatar
with the car running, unplug your idle air control valve. did it change the way the engine is idling? if not the IACV is bad. If it runs different then you have a leak in your intake system. the most likely culprit is the gasket that connects your throttle body to the engine. with the IACV plugged back in and the car still running spray a little FLAMABLE brake cleaner or starter fluid around your throttle body checking diffrent spots with little squirts. when the engine revs up a little, you've found the leak. Good luck
supplybfk
Oct 22, 2010 09:28 PM
azlegend
Feb 15, 2009 12:35 AM
jhorse
Nov 14, 2007 07:46 PM
cub_master
Jun 14, 2007 05:25 AM
blk_integra
Sep 4, 2006 08:48 PM
