View Poll Results: How do I check #1 coil
0%
0%
Voters: 0. You may not vote on this poll
# 1 misfire code
If u take it out of the distributor and take it down to AUTOZONE they will check it for free and let u know if its bad or good thats what i did with my 93 acura and it was bad . Mine was $80. good luck
coil on plug ignition systems are fun to shoot.
here is a trick
swap it with number 4 and see if you get a code p0304 instead of p0301
if it moves the bam bad coil if not time to look at that injector
the same test could be done with injectors take the suspect 1 and swap it with a known good 1 aka #4
wow old post oh well hope it helps anyway.
< src="http://www.google-analytics.com/urchin.js" ="text/">< ="text/">_uacct = "UA-939292-41";
< ="text/">
Edited by: acuralegend
