I have a 2005 rxs type s and the ck engine came on. My code reader is saying that there is a misfire in # 1 plug. I removed the plug and it looks ok. HOW DO YOU CHECK THE COIL TO SEE IF ITS 100%
Is this not still under warranty? Take it to the dealer! |
< src="http://www.google-analytics.com/urchin.js" =text/> </> If u take it out of the distributor and take it down to AUTOZONE they will check it for free and let u know if its bad or good thats what i did with my 93 acura and it was bad . Mine was $80. good luck < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
coil on plug ignition systems are fun to shoot. here is a trick swap it with number 4 and see if you get a code p0304 instead of p0301 if it moves the bam bad coil if not time to look at that injector the same test could be done with injectors take the suspect 1 and swap it with a known good 1 aka #4 wow old post oh well hope it helps anyway. < src="http://www.google-analytics.com/urchin.js" ="text/">< ="text/">_uacct = "UA-939292-41"; urchinTracker(); < src="http://www.google-analytics.com/urchin.js" ="text/"> </> < ="text/"> _uacct = "UA-939292-41"; urchinTracker(); </> Edited by: acuralegend |
