vibration at 40mph
Old Jun 17, 2010 | 10:10 PM
BIGDOG8540's Avatar
Default vibration at 40mph
My 05 TL vibrates when it drives a steady 40mph. If I give it more gas (press pedal hader) it goes away. car has 74,000. never abused or crashed. Anyone have any sugestions? Asked dealer and there answer was to change transmission. They couldnt tell me what was wrong.
Old Jun 18, 2010 | 04:13 PM
Exclamation Hi Member
!st things to be checked before you spend any $$$$$ is to have the rims, tires and the wheel bearings checked on by someone you know who isn't a idiot who says transmission right away...
Old Jun 22, 2010 | 10:01 AM
jg atl's Avatar
Default Agree with Ang.....
Take the car to a shop that has the Hunter GSP9700 road force balancing machine. They can check the balance of the wheel and tire and also verify that you don't have a bent wheel. Then move on from there to check wheel bearings, CV joints, and suspension bits.
You can find a Hunter GSP9700-equipped shop here:
Old Dec 2, 2010 | 10:48 AM
Lightbulb Hello Member **
Did you ever get this problem handled ?
Old Dec 6, 2010 | 11:17 PM
Leeper's Avatar
Default Piggy backing from "vibration at 40mph"
02 TL-S, never damaged, similar problem. However, my vibration starts around 40 - 42 and goes away around 50. It is barely noticeable under light acceleration and very noticeable under a load (like accelerating up a grade).
I do have aftermarket wheels and I also have the factory set. I am going to put the stock wheels on to rule that out. Based on the fact that it is more pronounced under a load, I am thinking it is not a balance issue. In fact, if I coast down a grade and gain speed through that range (40 to 50) the issue is non-existent.
Thoughts? Suggestions?
Leeper
Dec 29, 2010 02:25 AM
csteve2
Oct 15, 2009 01:05 PM
