2006 TL electrical problem
Old Dec 25, 2009 | 06:14 PM
ti_asp's Avatar
Default 2006 TL electrical problem
Recently my TL has developed an issue that I assume is associated with a switch in the automatic shifter mechanism. When the ignition switch is first turned on all dash lights and gages are lit and operable, but as soon as I try to engage the starter all power is lost (everything goes dark). This has happened twice.
If I turn the ignition off and wiggle the shifter sideways in the gate for park position, then turn the ignition back on, battery power is restored and the car will start.
Has anyone else had this problem? What is the cause and solution?
Thanks
Old Jan 19, 2010 | 09:48 PM
lanejared's Avatar
I had problem but not same as yours.
I solved my high-mount brake light problem, The solution was to replace the brake light switch, which is located on the brake pedal.
The switch was less than $7.00.
It was very easy to install.
Old Feb 11, 2010 | 01:03 AM
greattik's Avatar
Just replac the battery with a larger capacity battery and you have to use the battery that Acura specifies.
Old Feb 12, 2010 | 02:23 AM
martizt's Avatar
Yes i think you can replace the brake light switch and try with the battery larger capacity and use the battery that Acura specifies.
Old Mar 9, 2010 | 09:01 PM
geeyay's Avatar
Aside from that, have you checked your fuses?
dphiomega
Apr 4, 2009 08:34 PM
kdkrone
Feb 1, 2009 12:32 PM
tejadasammy
Sep 25, 2007 03:45 AM
piper04
Feb 8, 2007 03:27 PM
UTI GUY
Jan 2, 2007 05:14 PM
