electrical problem
Ok, so i decided to pull out the carpeting in my car cause it was very dirty and i wanted to hose it down. So, i pulled everything out with no problem and the only electrical i touched was the antenna wire going into the back of my stereo. I put everything back, including the wire and now im having problems. The interior lights wont work (headlamp) and my clock is flickering (along with a few of the lights on the dash). When i try to turn the stereo on, all it does is flash a few times and then shuts off. I looked at all of the connections into the stereo and they are good. i dont think its a fuse because they lights are still flickering. What should i do?
how did you clean that carpet?
does it do this flickering with the engine running?
did you pull the carpet out of the vehicle?
it sounds like the batt is very low. and need recharging.
what year is this tegra?
