05 RL - ROUGH RIDE - SHUTTER
Old Feb 21, 2009 | 09:41 AM
RL- BLK ON BLK's Avatar
HELP
Has anyone else experienced a shutter - rear shimmy - hard to explain. I experience it on rough roads - rear seems to want to "kick out". Also experience on icy snow covered roads - alway compensating steering wheel to keep straight.
Its an 05 RL with 45k - dealer says suspension is solid. Tires are all seasons with 75% tread. Any input will be apreciated
Old Feb 23, 2009 | 01:03 PM
ok you have a hard bump shimmy...and solid suspension.
then you have a dealer that isnt taking the time to find this problem.
you have a vehicle control issue. TOP priority in my book.
but.
if you have a second set of tire, then get those put on and see if it stops. if you dont then get them rotated and see if you "shimmy/kickout" moves to the front.
i suspect you have a shock with a worn spot in the center of its travel.
its not leaking and wont look like a bad shock.
if it kicks to the passenger side i would suspect the right rear shock.
if driver side i would look into the left shock.
i suspect you have a dealer that isnt doing there job.
Old Feb 23, 2009 | 07:47 PM
Great advice - thanks for taking the time.
I thought it was a shock/strut issue also but dealer saw no sign of leakage and dismissed as a cause of problem. I will approach them again.
Old Feb 23, 2009 | 10:15 PM
Take it to a suspension shop instead..
cbads06typeS
Dec 10, 2007 02:40 AM
mbri
Nov 5, 2007 01:05 PM
87 legend
Oct 6, 2007 05:37 PM
rstep1
Aug 20, 2007 08:05 AM
kinkade16
Feb 26, 2006 10:04 AM
