2017 Timing Belt
Old Dec 7, 2024 | 10:08 PM
17RDXPWC's Avatar
Default 2017 Timing Belt
Bought this AWD RDX about 6 months ago at 91k miles. Started noticing a vibrating type noise on cold start ups.
It had the timing belt and tensioner done at 60k miles according to Carfax. Turns out the noise WAS the timing belt tensioner. Had the water pump and coolant changed also(Acura Coolant). Now it's nice and quiet on start ups & drives nicely.
One mechanic said it was the oil filter. Said it didn't have the check valve in it. Well I changed the oil and filter to a Mobile One filter with the check valve. No difference. Feel so much better the car is fixed properly now!
Old Dec 12, 2024 | 05:48 AM
John from PA's Avatar
Don't use that mechanic, again, EVER!
Old Dec 16, 2024 | 07:55 AM
RabbitAgain's Avatar
Default Oil filter causing noise?!?
Yes, run (don’t walk) from this charlatan. It can be difficult to find an honest mechanic, but they are out there.
gentlejax
Mar 7, 2024 06:26 AM
pcola
May 5, 2021 09:32 AM
m_townsgreatest
Mar 11, 2008 02:32 AM
prdude
Oct 19, 2007 10:09 AM
Cobra611
Apr 26, 2007 10:59 AM
