2017 rdx with tech package. Infotainment system crashing! Help!
Old May 13, 2024 | 01:15 PM
Ckjmom's Avatar
Default 2017 rdx with tech package. Infotainment system crashing! Help!
I was driving down the road when both screens went black. My infotainment system and gps screen keep turning off and on. Radio works when it’s on. Touchscreen works sometimes. It’s not dead, just very intermittent. Sometimes the screens will be black with radio working and other times both screen turn green or have lines running across. I’ve checked fuses and unhooked battery for a day with no change.
any other suggestions before replacing my entire infotainment system? Thanks!
Old May 15, 2024 | 06:16 AM
John from PA's Avatar
Locate the fuse and remove it for a few minutes, then reinstall. That should provide a reset. 2017 Acura RDX fuse location might be of help in locating the fuse. Some people have also suggested a reset by disconnecting the battery negative terminal for about 30 minutes, then reconnecting. If you do this you likely will be prompted about further steps for a reset like holding the power button for 5 seconds.
Broomzoom
Jan 25, 2024 06:25 PM
RobertRichard
Nov 16, 2023 01:48 AM
gbl5067
Jan 23, 2023 09:12 AM
LDH
Feb 3, 2022 04:24 PM
JimmyJohns
Nov 19, 2010 02:50 PM
