92 legend overheat
have a 92 legend and after about 20-30 mins run time he temp gauge will peg out and i have to shut it down. IF i open the rad cap, bleed off pressure, refill it will run again at normal temp for anothe 20 -30 mins......what the heck is this....wouldnt a bad stat do this within 10 mins ???
all help greatly appreciated.....and rad and cap is within a year old and i see no leaks.
The chances of three separate
thermostats being faulty are extremely remote. We
suggest verifying the in-dash temperature gauge using a
temporary thermometer in the acura integra radiator. It is possible
that in-between thermostat changes, your car lost a
small amount of coolant, either externally or internally
from the engine which would cause the temperature gauge
to fluctuate.
to fluctuate.
If by some chance a head gasket has started a leak or if a head has
cracked, it can cause exhaust gas to excape into the coolent
system.
This will displace the coolent and cause a over heat.
It usually will take 20-40 min to do so.
I would go to a trusted shop (or 2) and have a combustable leak test performed on the radiator.
Lets just hope its a air pocket within the system.
But the test should only take 30min tops.
If you were in Fort Collins Colorado i would do it for you for free.
system.
