1994 Legend Speedometor bouncing
Old Apr 21, 2007 | 11:41 PM
rstep1's Avatar
My speedometer bounces every now and then, sometimes it does not register the speed correctly, I am thinking that the cabke going to the transmission is going bad, any ideas?
Old Apr 24, 2007 | 04:16 AM
dreadluck's Avatar
Your speed sensor is bad, you either replace it or you can by a speed sensor repair kit its about $75.00 on ebay. Onced its prepaired, all your issues will go away.
Old Apr 24, 2007 | 12:55 PM
rstep1's Avatar
Thanks for the info, where is the speed sensor located?
Old Apr 26, 2007 | 12:16 AM
acuramastertech's Avatar
THE SPEED SENSOR IS IN THE FRONT OF THE EXTERNAL DIFF. YOU ONLY NEED TO BUY THE ELECTRICAL PORTION OF IT. IT SCREWS INTO THE TOP OF IT. YOUR CAR HAS NO SPEEDO CABLE. IT IS ELECTRONIC. THERE IS A MECHANICAL GEAR SHAFT AND HOUSING THAT SLIDES INTO THE DIFF WITH THE ELECTRICAL PART ON TOP. I USE TO CHANGE THESE ALL THE TIME FOR THE SAME PROBLEM[img]smileys/smiley7.gif[/img]
Old Apr 26, 2007 | 01:34 AM
rstep1's Avatar
Thanks alot for the info, this will help me a lot. One other thing, my dash lights have went out, you know.... the spedometer needle and my gas needle are hard to see now... is there a way to fix this? this is on a 1994 Acura Legend.
shwtyme
Jun 3, 2011 09:44 PM
kurts45
Dec 28, 2007 09:48 AM
kurts45
Dec 28, 2007 09:44 AM
johnnytoo
Oct 17, 2007 08:28 PM
Ray94Acura
Jan 20, 2006 12:36 AM
