right side axle
Old Aug 19, 2007 | 11:41 PM
integ89's Avatar
i think i broke my axle on the right side because i was at a light in the left turning lane and i pulled up the e brake and dumped the clutch to put out alot of smoke and i heard a weird sound my friend behind me said that it was only one wheel spining but i cant take sharp turns and it makes a sort of grinding\clicking sound i need help if it is my axle how much does it go for and how hard is it to do can i do it myself or is it something i should leave to the mechanics?
Old Aug 23, 2007 | 08:07 AM
yup im betting on a popped axle or very soon the be popped.
axles are around 100 remaned used 25-50 new oem as much as 500
the install is easy.
pop the lower ball joint loose
remove the axle nut
remove the lower spring/shock bolt
then pop the axle out
reverse it to install
lube the splines and seal surfaces
dont forget a NEW cotter pin 1/8X1.5
and dont forget to punch the axle nut so it wont counterspin off
wheel tork at 100 foot pounds
i can do this in around 15 min.
RuNnInG_RiOt
Mar 2, 2009 07:00 PM
bospet40
Nov 29, 2008 05:12 AM
92integrals
Aug 23, 2007 08:02 AM
teg'00
Nov 1, 2006 01:26 PM
94blueteg
May 13, 2006 06:02 PM
