hard starts when engine is warm
Old Jan 6, 2006 | 06:20 AM
tegnitrous93's Avatar
car starts fine when engine is cold but when engine is warm it cranks to many times before it fires, anyone know what could be going on, to narrow it down ive done the following already, ive changed out old plug wires, ive changed out slightly burnt rotor, ive pulled the spark plugs and cleand them, ive pulled injectors and cleaned them including the small filters in each injector, ive checked the conections on the ignition control moduel,so far no luck. Help Please Anyone!!!!!
Old Jan 7, 2006 | 04:58 PM
spliff's Avatar
nt sure if it will help but u can try the fuel filter i had the same prob with my 89 accord last year and that fixed it
Old Jan 9, 2006 | 01:36 AM
ugly86integra's Avatar
you might have a leaking injector. i've had that problem with a couple tegs. lol when i shut off the car, the bad inj. would keep dripping until all of the fuel pressure was gone, thus putting lots of raw fuel in the intake and flooding the engine. if that is your problem too, it'll help to hold the gas pedal down while starting it, and keeping it reved up a lil until it clears out after it starts. this is just one common problem, but it could be lots of other things too like a weak ign. coil, or a bad connection in your engine wiring harnes, or lots of other things! lol
Old Jan 15, 2006 | 04:00 AM
tejadasammy's Avatar
i had the same problem with my 90 integra. try turning the ignition key toon but dont crank the engine. then listen and you will hearhear a click when the engine light turns on and when it turns off, youSHOULD hear another click. if not thenit is probably your main relay. (which is hard to find). id try that and see what happens
Old Mar 23, 2006 | 05:00 PM
helpmyacura's Avatar
mine does the same but i have to either replace or fix my fuel injector it has something mechanically wrong with it
tejadasammy
Nov 25, 2008 09:33 PM
troys90gs
Mar 13, 2008 04:31 AM
Acura_tuning21
Apr 28, 2007 01:59 PM
robairline
Mar 8, 2007 05:56 PM
artizzl
Sep 18, 2006 11:27 AM
