please help integra brakes
Old Jan 23, 2006 | 10:44 PM
mbandoni288's Avatar
Hi I have a 90 integra (non abs) with a brake problem it is my caliper on the driver side makes a clicking noise, the noise stops when i press down on the brake pedal. It seems like it is stuck on the disc. The disc moves but not as freely as the other side. It even creates a vibration in the steering wheel . I put new discs and pads on it. I even tried a junk caliper. The junk caliper was froze on there too but way worse. Please help
Old Jan 26, 2006 | 01:17 PM
Patrick's Avatar
Administrator
have you tried jacking up that side and spinning the wheel by hand, and trying to make sure that it is the brakes, and not a half shaft or something?
Old Jan 27, 2006 | 12:29 PM
yes I have jacked it up and spun the wheel, and have narrowed down the problem to either a bad line or a bad master cylinder.
Old Feb 3, 2006 | 01:55 PM
Patrick's Avatar
Administrator
hmm..its an odd problem...let us know what you find out.
Old Feb 3, 2006 | 06:19 PM
Ok Looks like my master cylinder piston is stuck not enough to lock on but just enough to be annoying. I ordered the mastercylinder off ebay and am going to put it on as soon as it comes in. hopefully it works if not I ll have to try putting on a brand new caliper. I will keep you posted on my discovery of the solution.
Old Sep 17, 2006 | 09:51 PM
2 more things to look at befor buying stuff
ABS pump may have a valve stuck....if it was a master cylinder it should effect both wheels on the same axle.
hopefully it is a soft break line that is the problem.
I have seen a soft line crack on the inside and creat a flap that
prevents low pressure from returning to the mastercylinder
causing a drag on the caliper.
Also look to see if a hard line is pinched.
Rule of thumb on soft lines...if its cracked on the outside even if its ittybitty replace it
aquant
Mar 8, 2008 12:20 PM
MarinePeter
Mar 5, 2008 08:32 PM
ralphy1798
Dec 24, 2007 10:11 AM
johnnyz
Nov 8, 2006 07:38 PM
mbandoni288
Mar 25, 2006 01:30 AM
