Help! OBD II Code P0141 - O2 Sensor....
Old Oct 22, 2007 | 12:42 PM
jg atl's Avatar
The full error message from my OBD II scanner says: O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2).
So the questions are:
1) Does this mean that the actual O2 sensor is bad?
2) Where is this sensor located?
I'm guessing that the sensor is bad and also that it is maybe after the catalytic converter, but not sure. Are there any online sources for parts diagrams?
Car is a 96 3.2 TL with 92K miles. Other than routine maintenance, this is the only thing that has gone wrong with this car.
Thanks in adavance!
Old Jan 14, 2008 | 09:11 PM
super4dodge_36's Avatar
I just read your message and i worked for a muffler shop and changed them out all the time. Yes, that indicates that th O2 sensor is not functioning properly and needs to be changed. Bank 1 is the circuit and sensor 2 is the number two sensor. U have 2 of them one is located either up by the head on the pre-catalytic convertor infront of the radiator or it is located just past the oil pan. Ur second one should be just down the pipe from that one. But, yes it is bad.
Old Jan 17, 2008 | 09:37 PM
4williamn's Avatar
first clear the code and then start the car and hold at 3000 rpm for 3min. if the code dose not come back then it is an interminit problem. if id dose come back more then likley the sensor is badTL9598A11080A.ziphere is step by step on how to diag. hope it helps!!!
Old Feb 15, 2008 | 03:36 PM
jg atl's Avatar
Thanks 4William. Nice doc. I reset the CE light with my OBDII reader and it came back immediately on restarting the car. Bad sensor. Its #2 down by the cat. Fixed now and no CE light!< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
Old Mar 11, 2008 | 03:39 AM
kerpal's Avatar
Car is a 96 3.2 TL with 92K miles. Other than routine truck partenance, this is the only thing that has gone wrong with this car.
Thanks in adavance!
Definitely the Sensor is the problem.. The only problem is, I dunno where it is located..
Old Mar 11, 2008 | 11:22 PM
4williamn's Avatar
&lt; src="http://www.google-analytics.com/urchin.js" =text/&gt; </>TL9598A11003A.ziphope this helps.. this shows locations of sensors and other stuff &lt; =text/&gt; _uacct = "UA-939292-41"; urchinTracker();
let me know if it helps</>
Edited by: 4williamn
larryj54
Jul 21, 2012 10:52 AM
Mr Douglas
Mar 13, 2012 05:41 PM
snutmeez
Aug 13, 2010 10:33 AM
kracuraforum
Jan 19, 2009 11:15 AM
Tonyng101
Jun 10, 2008 10:09 PM
