gsr rebuild
I'd say get the engine to the shop.....once they "check it out" then you will know what to get....if they have to turn the crank, you'll know what bearings will be needed.....if they need to bore the cyl, then you know what pistons and rings will be needed.
My point, find out exactly what will be needed before buying parts. Once you know the "spec's" of what you need to go back with, there are several online places you can order what is needed.....good luck.
fortheerecord
Oct 14, 2012 12:33 AM
