gsr rebuild
1997 acura integra gsr (B18C1) . im getting ready to rebuild it . I need help on ... good shop manual , good rebuild kit , & any tricks I need to know . thank you for any help ............... steve
Help please
all I need is info on where I can get a "shop" manual
7 rebuild kit to fix my gsr . give me a helping hand ...... thanks .. steve |
Sorry Steve, can't help you on that. Maybe one of the other guys in here might know.. :)
help eeded
(Post 15402)
**** thank you . hoping for help on a good rebuild kit ......... steve |
gsr rebuild
I found a good manual , now just need info on a good rebuild kit ...... steve
gsr rebuild .
found a local machine shop that has good parts & machine work . thanks .. steve
************ what sealer is best for the gsr motor ???? |
What things to do you have in mind? What work do you want?
complete rebuild !
I'd say get the engine to the shop.....once they "check it out" then you will know what to get....if they have to turn the crank, you'll know what bearings will be needed.....if they need to bore the cyl, then you know what pistons and rings will be needed.
My point, find out exactly what will be needed before buying parts. Once you know the "spec's" of what you need to go back with, there are several online places you can order what is needed.....good luck. |
