90 teg m/t slips when cold??
Old Mar 9, 2007 | 01:06 AM
mr.potatoking's Avatar
Old Mar 10, 2007 | 01:48 AM
AKinDen's Avatar
do you mean slips like pops out of gear?
Old Mar 10, 2007 | 09:31 AM
no like 1st gear is fine 2 if i hit the gas the tranny slips but sometmes it dosent??
Old Mar 11, 2007 | 03:18 PM
AKinDen's Avatar
When it slips, do you lose power, like the engine reves up but you don't go any faster or does your shifter physically pop out? once the car is warm nothing slips right?
Old Mar 11, 2007 | 07:24 PM
shifter stayes in geAR RPMS jump then i let off on gas a lil bit then it catches and when its warm its ok only cold condition
Old Mar 11, 2007 | 08:00 PM
AKinDen's Avatar
Is your tranny fluid full? Kindasounds like a clutch going out, but it's weird that it's only happening from 1stto 2ndgear when it's cold. Sorry I'm not more help. I'm gonna move this to general techEdited by: AKinDen
Old Mar 12, 2007 | 12:03 AM
1st is solid 2,3,4,and 5 slip but 2 is more solid then the rest also r grinds every time???
Old May 26, 2007 | 04:44 PM
snardos's Avatar
It has to be something with your clutch. There is no way a manual transission can slip becuase there are actual gears meshing with each other. So for the gears to slip they would have to be worn down completelyand they would never work. Also then the problem would be with only one gear or all the gears and wouldn't change with temperature.
asimms21
Jan 30, 2008 04:21 PM
blackteg
Nov 26, 2007 05:57 PM
Ls/Teg
Nov 15, 2006 03:26 AM
FUNK1196
Oct 29, 2006 01:07 PM
Jul 30, 2005 03:16 AM
