Driver Power Window Motor
Old Jan 29, 2007 | 02:35 PM
vbw12003@yahoo's Avatar
I have a 1997 Acura CL, the driver side power window motor has died, the window is stuck in the down postion, anyone have any suggestions how to go about trouble shooting?
Old Mar 15, 2007 | 02:28 PM
Bratva4's Avatar
Hey there, you might have been fixed this problem, but if you haven't here is why it doesn't work. The motor that does the power window should be ok, but the string that goes through the motor might have been broken. here is what i did when i had this kind of the problem: i took the sting from bike( bicycle) and exchange it with a broken one, and now it works. Try this, if it doesnt work, reply me.
Old Nov 11, 2007 | 09:24 AM
acura1998CL3's Avatar
In my case, I think the wire did not break, but became kinked, causing the motor to slip, build up torque, and yank the string out.
Using the original wire, I tried placing the one dislodged nub at the end of the wire (of two) back into the track jockey; unfortunately, the kinks make the motor slip, and the whole wire "loop" seemed too tight for the track.
Since the motor is still good, I'd really rather not reman this assembly, but I could use a few tips.
coloradowest
Jul 18, 2011 09:40 PM
KissMyS
May 27, 2008 11:20 AM
grady7
May 2, 2008 05:19 PM
Tyler Adams
Aug 18, 2006 01:17 AM
samiam1017
Jul 17, 2006 10:52 PM
