VSA ! issue 2006 Acura TSX Automatic
Recently my VSA light and the "!" turned on as well, its not letting my cruise control to work. My question is how can i check if one of my speed sensors are bad? I recently took them out, cleaned them, put them back on, now when i start the car, it takes a few seconds to turn the VSA light on the cluster. Before i cleaned them it was on as soon as i started the car. The problem is a pain and i need to fix it!! Can someone who knows what to do help me?
ALSO: had a code run up U0122 Fcan/vsa THANKS!! |
Let's see if someone chimes in on that subject..|I'm also going to research it my self thru my Awesome Friend Mr. Google :)
solution
Fixed the problem myself
" My 2006 had a similar problem, no mechanic could figure out what was wrong with it. So i ended up finding out that my solenoid sensor was bad. Replaced it and BAM lights turned off, Such a relief. Part number 37250-PRB-A01 located on top of the solenoid. The sensor could be green, blue, or gray. You can identify it easily by looking at the part number. " sensor can cost around $40-$60 new on ebay |
You might wanna check the BCM as well. I guess there might be some problem in it.
the same solenoid sensor trouble has been with me as well in past and i was juggled much with it then did a fix on it .. good to get that you got that too .. but what to check if to find the quality sensor as there are many in the market but how to differentiate among them
I purchased mine off ebay ex: http://www.ebay.com/itm/Genuine-OEM-...#ht_396wt_1124
They all seem to look the same, I just go for the "genuine" parts |
this too is a tough task in today's world as there are many so similar looking designs of products are coming that makes it hard to recognize what is real or fake
| All times are GMT -5. The time now is 01:02 AM. |
