VSA ! issue 2006 Acura TSX Automatic
Old Jan 14, 2013 | 07:20 PM
oleglyashenko's Avatar
Default VSA ! issue 2006 Acura TSX Automatic
Recently my VSA light and the "!" turned on as well, its not letting my cruise control to work. My question is how can i check if one of my speed sensors are bad? I recently took them out, cleaned them, put them back on, now when i start the car, it takes a few seconds to turn the VSA light on the cluster. Before i cleaned them it was on as soon as i started the car. The problem is a pain and i need to fix it!! Can someone who knows what to do help me?
ALSO: had a code run up U0122 Fcan/vsa
THANKS!!
Old Jan 20, 2013 | 12:58 PM
Let's see if someone chimes in on that subject..|I'm also going to research it my self thru my Awesome Friend Mr. Google
Old Dec 14, 2013 | 12:32 PM
Default solution
Fixed the problem myself
My 2006 had a similar problem, no mechanic could figure out what was wrong with it. So i ended up finding out that my solenoid sensor was bad. Replaced it and BAM lights turned off, Such a relief.
Part number 37250-PRB-A01
located on top of the solenoid. The sensor could be green, blue, or gray.
You can identify it easily by looking at the part number. "
sensor can cost around $40-$60 new on ebay
Old Feb 3, 2014 | 02:38 AM
rylees's Avatar
You might wanna check the BCM as well. I guess there might be some problem in it.
Old Feb 3, 2014 | 10:25 PM
Bradleywhites's Avatar
the same solenoid sensor trouble has been with me as well in past and i was juggled much with it then did a fix on it .. good to get that you got that too .. but what to check if to find the quality sensor as there are many in the market but how to differentiate among them
Old Feb 4, 2014 | 10:14 AM
Thumbs up
I purchased mine off ebay ex: http://www.ebay.com/itm/Genuine-OEM-...#ht_396wt_1124
They all seem to look the same, I just go for the "genuine" parts
Old Feb 11, 2014 | 10:51 PM
BrettCramer's Avatar
this too is a tough task in today's world as there are many so similar looking designs of products are coming that makes it hard to recognize what is real or fake
sergeyz2002
May 26, 2012 06:41 AM
miowen1
Jun 12, 2011 05:09 PM
WavyGravy20
Oct 9, 2010 11:13 PM
Alex5357
Jan 15, 2010 02:07 AM
bloke279
Sep 7, 2006 02:43 AM
