thinking new strut
Old Sep 23, 2012 | 08:21 PM
Master Guru Sin's Avatar
Default thinking new strut
the ride quality has been diminishing slightly over the past couple of weeks, could this be that my struts are going bad? i feel like i bounce a little too much but also that when i go over bumps they do make some noise. any recommendations for replacements? nothing to extravagant. something good that'll last a while.
Old Sep 24, 2012 | 10:01 AM
jg atl's Avatar
Remind me again of year and mileage of your car.....
If you have a bit too much bounce, it very likely is your shocks (dampers). However the noise could be from worn suspension bits or even the shock bearing in the top of the MacPherson strut.
Personally, I like Bilstein shocks, but any reputable brand should work fine and last plenty long. Especially if you are not tracking or autocrossing your car.
Old Sep 25, 2012 | 01:29 PM
NC_Tech007's Avatar
Koni's is my recommendation. Bilsteins tend to be overdamped in the bound so they are a little harsher than stock. Koni's are adjustable and a lot of people compliment that they control the stock springs even better.
Old Sep 25, 2012 | 02:40 PM
Talking Hi Member
Koni and Tokiko come to mind as good units to install...
click the sign image.
Old Sep 26, 2012 | 11:26 AM
the car has almost 300,000 miles and drives like a champion. outside of the current ride quality but that is a new issue. just put new brakes pads and rotors. also i just found out this morning that when i took the car to get the wheels balanced i don't know what they did but the front passenger and rear driver tires were over inflated and the other two were under. after i fixed that it improved, just the noise over bumps is what i am getting. Also im changing the lower ball joint on driver side front.
Old Oct 8, 2012 | 03:34 AM
WallisXylia's Avatar
Huge Thing For Movies --- One Tree Hill Season 9 DVD,Creat excellence for your life
Old Oct 10, 2012 | 12:02 PM
NC_Tech007's Avatar
Bilsteins are good too, but they tend to be a little stiffer.
viking99
May 7, 2010 01:34 PM
charles myers
Nov 2, 2009 01:04 PM
amosby
Dec 21, 2007 09:27 AM
steves
Apr 8, 2007 10:22 AM
BlackTL
Feb 9, 2007 04:38 PM
