Reset 2014 Acura TL Computer?
Hello All,
My computer has not been working on my 2014 Acura TL. The external temp is usually about 10 degrees above the actual temperature and the compass is not working either. I have tried to recalibrate the compass by going into setup mode and driving in 3 circles which worked for a few days but then it stopped working. I was heading North today and the compass told me I was heading West as an example. Anyone have a good video on how to do a reset? I have seen a generic video which says to disconnect the battery and place a wire between the two terminals (of the car, not the battery) to get all of the electricity to dissipate and then turn the lights on. I have seen warnings which say you must have the password for the radio. I am the original owner and I am not sure if I have the password. Thanks, Bill |
You can retrieve the radio code at Radio code or by following the steps at Find radio code. Since you say you are the original owner, you should also have received a white credit card sized card (labeled "Anti-theft ID card") with the radio code and the navigation code (if equipped with the navi option). The card is often said to be in the glove box or owners manual. Having a 2013, I don't remember where mine was stored at time of delivery. My code is a 5-digit number. If the display is blank search for the radio fuses, I believe there may be two. In that regard, see Fuse location
By the way, I personally would not use any wire to short out the battery terminals. Do the wrong thing and you could fry a lot of components. If you want to do a reset, disconnect the negative terminal, to play safe wrap it in a rag. Then disconnect the positive terminal, again to play safe wrap it in a rag. Let things sit for about 5 minutes; as a form of maintenance clean the terminals while you wait, then reconnect the positive, then the negative. |
Thanks John @John from PA . Appreciate the advice. I probably have the card you mention as I think I have seen it. Will following your advice about wrapping the terminals in a rag reset the computer?
Originally Posted by bpatters55
(Post 17934)
