HID Conversion
Hi All,
I'm new to the forum and would like to say that I have come across alot of interesting topics covered here.
I have a question I would like to ask the member. I have a 2002 3.2TL and was wondering if it was a easy process to replace the OEM HID lights with a Slim Line HID aftermarket system? Could I use the existing relays to handle flicker and just splice the connections for the new Slim Line balast that I would install in the same position as the OEM balast onto the existing wires. Is this recommended or not. I find that the OEM balast are just too expensive @ $350.00 each from Acura.
Hope to hear from someone soon as I have to repair one of my non functioning balast.
Thanks for all the viewers of my post but I have figured it out myself. All I need to get is a D2R/D2S HID conversion kit or buy the connector from the Ballast to the bulb seperately for around $50 bucks. I can use my existing OEM wiring harness in the car already.
I do have another question though. Does anyone know the type of connector that plugs into the ballast? I would like to get the mating connector if at all possible so I don't have to butcher my OEM wiring. I would much rather create wiring adapters of my own so that everything can be returned to its original state if necessary in the future.
I had the dealer ship try to replace the bulb and that did not do it. Now they are saying I need some other controller piece that is like 650.
there has to be a better solution.
can you give more info on what kits are available i have a 20033.2TLwith nav
thanks for your help.
