Driver door lock plug will not work
My driver side door lock plug is not working. I can unlock the driver and passenger side doors from the passenger side switch, so I know it isn't the door actuator. I have also put the passenger side switch that does work on the driver side plug and it still doesn't work. I also have two other lock switches, since I replaced my door handle assemblies, that I have tried on both the passenger and driver sides. They all work on the passenger side, but none work on the driver side. I do not know what to check next, it appears the problem is the plug forward into the harness I guess. Sorry if this has been asked before I searched on the forum and everywhere else, but I haven't found this particular issue. My car is a CL, but not as many people own them as the TL. The fix would be the same on either car.
