Acura tl 2004 headlight question.
ACURA TL 2004: HEADLIGHT QUESTION.
I bought a used ACURA TL with 122K miles.
I live in Texas, where some of the roads have only one lane - each way. That being said, I find the light from my headlights, WOEFULLY INADEQUATE, when driving at night.
My questions:
1. Can I install an extra set of headlights - if so, which one would you suggest?
2. Do the bulbs need to be replaced (They are in perfect working condition), should I replace these with a higher intensity bulbs?
Any advice in this are will be highly appreciated.
Thanks in advance
My questions:
Thanks in advance
What kind of headlight do you have on your 04? Regular Halogen presumably? I also have an 04 with HID (High Intensity Dischage) headlights and they are fabulous. Rather than changing bulbs or adding lights (which would also likely be halogen), I would suggest finding a wrecked Gen 3 TL that has the HID headlights and buying those used headlights to replace yours. It is not a simple bulb replacement. You will need to replace the whole headlight unit as the HID's include a transformer needed to provide the proper voltage.
To see what they are like, suggest you go to an Acura dealer and test drive a new TL that has the headlights some evening.
Since you live in Texas, you could call Newman's Automotive for advice. They're a car repair shop in Austin. Here's their website where you can find their number. http://www.newmansauto.com/
