08 TL 3.2 Sometimes Revs up and down when sitting in park or drive
Old Aug 14, 2013 | 03:46 PM
jpeterson's Avatar
Default 08 TL 3.2 Sometimes Revs up and down when sitting in park or drive
Hey i just purchased an 2008 acura tl a little more than a month ago. The car runs perfect other than this one problem that just started. When im sitting still the rpms will go anywhere from 600rpms to 1100rpms. I talked to my brother briefly and he seems to think a dirty throttle body. A friend said mass air flow senor but i feel that would throw a check engine light, which there is no check engine light on. I was just wondering if anyone has an opinion on what it could be. I haven't checked the throttle body yet. Im thinking about putting in a cold air intake too.
Old Aug 17, 2013 | 11:30 AM
poorman212's Avatar
Super Moderator
Does this seem to happen only once the engine reaches normal op temp or does it happen only when cold?
A good cleaning of the TB is never a bad idea. A can or two of cleaner, a few rags and a bit of time.....be sure to get both sides of the butterfly....also an old tooth brush makes quick work of this job.
Old Aug 17, 2013 | 04:51 PM
jpeterson's Avatar
It tends to do it more when cold but it has done it when fully warmed up. I will definitely clean the TB and see if it stops.
varontron
Jul 30, 2010 10:09 PM
M E Berg
Mar 28, 2009 04:19 PM
jhorse
Nov 14, 2007 07:46 PM
equalizr458
Feb 24, 2007 06:50 PM
blk_integra
Sep 4, 2006 08:48 PM
