03 TL windshield washer nozzles
Old Feb 7, 2009 | 09:20 PM
nishant's Avatar
I was driving on highway and suddenly washers stopped working. Thought ran out of fluid but even when filled, no fluid out of nozzles.
I can hear pump working but no fluid out. Since it was running fine earlier, cannot imagine hose kinked. The nozzles appear screw type but cannot figure out whether these are adjustible.
Has anybody experienced similar issue or how to trouble shoot?
Old Feb 9, 2009 | 12:21 PM
is fluid coming out from under the car? like a hose broke???
there is a small filter screen on the washer pump itself you may have to pull the pump and see.
any chance the fluid could have just been frozen?
Old Feb 15, 2009 | 10:23 PM
nishant's Avatar
No leak from under the car when I use washer. No fluid out from nozzle either.
I check for washer level and there is fluid. I can hear pump working when I pull lever.
Some times I see just a droplet oozing out from one side but no always.
Wipers work but just washer donot. Waiting for temperature to rise above freezing to know whether that helps
Old Feb 16, 2009 | 12:12 PM
im betting its plugged with ice or junk you may need to pull the pump and clean it out.or it may need replacing.
Old Apr 29, 2011 | 09:29 PM
ndrewoods's Avatar
Bump. There's a possibility that the fluid is frozen. But have you checked the pump itself or the hose connected to it? The pump in your windshield washer system is not likely to fail, due to the infrequent use of the mechanism. Burn out is also unlikely, but several incidents can cause it to stop working. Power surges can knock out circuits that run electricity to the pump. In this case, the pump will stop working altogether. No water will flow through the lines. Accidents can also jar components in the pump and cause it to work at a slower pace. Prolonged use may eventually burn out the pump mechanism, and this results in a weaker fluid stream and eventually a non-functioning pump.
brodie
Jan 15, 2013 01:17 AM
Todd H
May 12, 2011 02:20 AM
voodoochild16
Jan 12, 2010 03:24 AM
gregfrey
Jul 26, 2007 03:15 PM
arca3x
Jun 13, 2007 12:56 PM
