High-pitched noise isssue!!!
Old Jan 18, 2008 | 02:09 PM
hermtm2's Avatar
Hi, my bro has 06 RSX with a super chargered. Someday ago he found abonormal noise under the hood. It was a shreded seperntin belt so he replaced the belt. After that the car makes high-piched noise when the streering wheel is turned regardless which ways. Sound like somethings squeeze inside the hood. By the way I counldn't find anything. The honda dealer who replaced the belt said that there wasn't a proper space between pullies and side of engine. The spacers where two spacer support whole pully structure should be replaced. But I don't where I can get the right spacer. Anyone can help me?
Thanks
Old Jul 18, 2008 | 09:24 PM
rsxracer's Avatar
well i had that problem once and i had the brakes changed and it stopped
Old Jul 21, 2008 | 09:13 PM
AKinDen's Avatar
try contacting the company that made the supercharger for the spacer . a shreaded belt on a supercharger set up is usually improper pulley alignment. but could also be from a pump that is going bad. since the steering is making noise check that pump first. if steering is good, check the pumps that are next in-line with the super chargers pulley. Oh yea, also check the belt tensioners.
karl
Sep 24, 2008 10:45 PM
jmitch99
May 1, 2008 01:41 PM
viper5405
Jan 17, 2008 05:22 PM
seether6955
Nov 10, 2006 02:34 PM
road_scholar
Feb 8, 2005 04:10 PM
