Heating problem with 98 rl
Old Dec 4, 2007 | 04:11 AM
joecus's Avatar
My heat only gets hot when idle high either driving or in park. I changed the coolant and thermostat and it did not help. I used the air bleeder to remove air. My old coolant was very clean but I have not ruled out a poorly circulating radiator. Can it be a heater core problem? Heat is fine when driving on highway or high idle. Please help, it's getting cold.
Old Dec 5, 2007 | 11:26 PM
i wonder if the fan blades on your water pump are worn?
does your engine suffer neer over heating issues at idle or slow engine speeds?
Old Dec 6, 2007 | 07:44 AM
joecus's Avatar
I am not overheating at all. I changed the coolant, it was clean no gook. I don't think the core is clogged. The fans work fine. I am going to bleed the air today. Also, the linkage on the flow to the heater seams to be working fine. I have 55k miles< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
Womesh
Dec 8, 2011 02:37 PM
dempsy
Jun 26, 2010 09:47 PM
4thand26
Oct 5, 2009 01:48 PM
iceman77
May 5, 2008 09:36 PM
pepsigirl1252
May 2, 2007 03:11 AM
