2005 Acura RL AFS Light Always On
Old Nov 21, 2007 | 07:15 PM
umoms's Avatar
My 2005 Acura RL AFS light is always on. Delaer replaced the AFS Unit and Steering Wheel Sensor but it didnt help. They said the next thing they can do is replace the headlamp unit which would cost $1500 and its not covered under warranty because it looks like its been in an accident.
Anyone have any other ideas what it could be before replacing the headlamp unit?
Old Dec 9, 2007 | 07:49 PM
gijoe151's Avatar
Have some pull the body code for you. If it was a B2130, the dealer did the right thing. See if it's the same code again. How many miles you have on it??[img]smileys/smiley2.gif[/img]
Old Dec 15, 2007 | 05:20 PM
umoms's Avatar
I used a ODD II scanner and did not get any codes. Do I need another reader to pull the code from it? It has about 30k miles< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
Old Dec 15, 2007 | 08:09 PM
gijoe151's Avatar
The only scanner that will comunicate with this car on the body side is the one that acura/honda dealers use
It's called a HDS (honda diagnostic system tablet). Also with the miles you have on your car tells me your still under warranty. you said 30k and 2005 model. Your warranty is 4 years or 50k witch ever happens first.
Hey dude, make then fix the car. Why would they charge you 1500 for a headlight if it's under warranty ?? Let me know about this.
Old Dec 16, 2007 | 08:17 AM
if there going to make you replace that headlight because it looks damaged i would call scott's auto recyclers at 1970-498-0662 ask for dave and buy a used 1 then install or have it installed. then if your still coding take it to the dealer and have em warantee it because it doesnt look like its been in a accedent any more < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-41";
Old Dec 17, 2007 | 08:03 PM
gijoe151's Avatar
So aaaaa UMOMS, is it warranty or is it damaged !!
Acuralegend makes sense and so do I
qatar
Nov 7, 2007 04:43 PM
qatar
Nov 4, 2007 12:49 AM
tramadsss
Apr 20, 2007 11:00 AM
daoryder
Jan 29, 2007 02:25 AM
lastturn
Jan 27, 2006 05:34 AM
