-   New Member Area (https://www.acuraforums.com/forum/new-member-area-9/)
-   -   NEED HELP/ INFO (https://www.acuraforums.com/forum/new-member-area-9/need-help-info-2014/)
super4dodge_36 Jan 14, 2008 08:59 PM
i have a 93 acura integra and i was wondering if u all can help me out. i have been having a problem with my temp rising. At high speeds its ok, but when i stop it'll be fine for a few minutes the starts to rise. when i saw that i changed the water pump cause it was leaking, it has a new radiator , timming belt, radiator fan switch , thermostat. when i put it all together i flushed out all the air out of the system. Now, thats all new but, IT IS STILL RISING i was wondering what could it be. thanks for your help
acuralegend Jan 16, 2008 02:54 AM
cools at speed but hot at idle.
are the fans working?
is your lower valence pannel on?
if that car is a little lean in the fuel managment it will go hot fast
and idle has different fuel curves then at speed.
i dont think its a head gasket because those tend to over heat at all conditions, worst at speed.
is your ac condencer plugged and not letting those fans do there job?
super4dodge_36 Jan 16, 2008 09:05 PM
The radiator fan came on twice when i replaced the radiator but hasnt sense but before i replaced the radiator it came on every now and then. the ac fan works but my air isnt charged i have to get it charged but i know that it works. I dont know what the lower valenace panel is. i had the idle set back to manufacterors specs for smog caause i replaced the soleinode in the distributor and somehow i had it ad 22 degrees instead of 18. could that be the problem?
4williamn Jan 17, 2008 08:45 PM
do you have to add coolant at all?
super4dodge_36 Jan 21, 2008 07:19 PM
no, i used too alot before i changed the radiator now i dont. im thinking maybe its the radiator fan relay. the fan used to stay on after the car was off for a few seconds then go off then when i changed the radiator it can on twice cooled it down and now it doesnt come on at all.
