-   MDX (https://www.acuraforums.com/forum/mdx-20/)
-   -   Help with MDX problem (https://www.acuraforums.com/forum/mdx-20/help-mdx-problem-3814/)
02mdx Sep 21, 2009 11:48 AM
I have a 02 MDX with 150k in miles and yesterday when driving on the highway I went to pass a slower car, when I depressed the gas the car jerked like I was hit, the rpms rose and then lowered and as soon as I let off the gas it went back to normal driving. This is the first time this has happened but today driving into work, I was able to recreate a couple of times same as above, once I let off normal driving resumed. Also, no Check Engine light came on.
I would appreciate any ideas anyone has and pointing me in a direction for a fix and estimated cost.
WheelBrokerAng Sep 22, 2009 12:25 AM
1 Attachment(s)
This sounds as tho your throttle cable might bind up and then unbind when you get opff the throttle..call your dealer and ask them if I might be right...
02mdx Sep 22, 2009 07:11 AM
Spoke with a Mechanic he said he thought that it might be the transmission fluid needed to be flushed and replaced and an additive added? This sound reasonable? I have not had the tranny fluid replaced, so this would be the first since the car was driven off the lot, by the way I am the original owner.
02mdx Sep 24, 2009 11:26 AM
Well the tranny flush didn't fix it, any more ideas on what it could be?
02mdx Oct 9, 2009 05:54 PM
Thought I would post again, seems like the hard jerk has stopped now the car just seems to shift out of gear. Basically when your driving it acts as though you have shifter the car into neutral press on the gas nothing rpms rise, if you take the shifter and move it to fourth the problem goes away immediately. This seems to only happen in fifth. Any ideas would be appreciated.
02mdx Oct 22, 2009 03:36 PM
Finally threw a code PO730 Incorrect gear ratio any idea what this means and how to fix it?
