New to Forum
Whats up guys? Im new to the forum, but I justgot my 3rd G1 Legend. It has a few bugs, I got it free from my ex. I thought this list might help some guys here. Enjoy..
86-88 G1 Legend A - Z Component List[img]smileys/smiley8.gif[/img]
A/C Compressor Clutch: Lower RH Front Corner Of Engine Compartment
A/C Compressor Clutch Relay: RH Front Corner Of Engine Compartment
A/C Condenser Fan Motor: RH Rear Of Radiator
A/C Condenser Fan Relay: LH Side Of Engine Compartment
A/C Condenser Fan Resistor: Lower RH Rear Of Radiator
A/C Pressure Switch: RH Side Of Engine Compartment
A/T Control Unit: Below Driver Seat, Under Panel
A/T Control Unit: Under LH Front Seat
Atmospheric Pressure Sensor: In Dash Relay Box
Blower: Below RH Side Of Dash
Blower Motor High Relay: Below RH Side Of Dash
Blower Motor Relay: Below RH Side Of Dash
Brake Light Switch: Top Of Brake Support
Chime: In Dash Relay Box
Climate Control Unit (LS): LH Side Of Engine Compartment, Behind Underhood Relay
Clutch Switch: Top Of Clutch Pedal Support
Coolant Temperature Sensor: LH Front Of Engine
Cooling Fan Control Unit: Behind Center Of Dash, In Heater Housing
Cruise Control Actuator: Lower RH Front Of Engine Compartment
Cruise Control Unit: Behind LH Side Of Dash
Dash Relay Holder: LH Side Under Dash
Dashlight Brightness Control Unit: RH Side Of I/P
Dimmer Relay: In Underhood Relay Box
Evaporator Sensor: Behind RH Side Of Dash, At Evaporator
Fan Control Unit: Behind LH Side Of Dash
Fan Timer Unit: Under RH Front Seat
Front Map Light: Top Of Headliner
Fuse & Relay Holder (LS): In Dash Relay Box
Horn Relay: In Dash Relay Box
Information Control Unit (LS): Above Glove Box
Key-Off Timer Circuit: In Integrated Control Unit
LH Brake Light Failure Sensor(1988): In LH Taillights
Lighting Relay: In Underhood Relay Box
Lock-Up Control Solenoid Valve: LH Front Of Transmission
Oil Temperature Switch: Top RH End Of Rear Valve Cover
PGM-FI ECU: Under RH Front Seat
PGM-FI Relay: In Dash Relay Box
Power Amplifier Relay (LS only): LH Side Of Trunk
Power Antenna Motor: LH Side Under Dash
Power Door Lock Control Unit: Front Of LH Door, Behind Door Trim Panel
Power Door Locks LH Rear Actuator: In Rear Half Of LH Door
Power Door Locks RH Front Actuator: In Rear Half Of RH Front Door
Power Door Locks RH Rear Actuator: In Rear Half Of RH Rear Door
Power Seat Front Lift Motor: Under LH Side Of Driver Seat
Power Seat Limit Switches: LH Side Of Driver Seat
Power Seat Rear Lift Motor: Under RH Side Of Driver Seat
Power Seat Reclining Motor: In Rear Of Driver Seat
Power Seat Relay Assembly: Under Driver Seat
Power Seat Sliding Motor: Under Front Seat Of Driver Seat
Power Seat Switches: LH Side Of Driver Seat
Power Window Control Unit: Front Of LH Door, Behind Door Trim Panel
Power Window LH Front Motor: In LH Door
Power Window LH Rear Motor: LH Rear Passenger Door, Behind Quarter Trim Panel
Power Window Relay: In Underhood Relay Box
Power Window RH Front Motor: In RH Door
Power Window RH Rear Motor: In Lower Of RH Rear Door
Radiator Fan Relay (L & LS): LH Side Of Engine Compartment
Radiator Fan Relay (Std.): In Underhood Relay Box
Radiator Fan Resistor: Lower LH Rear Of Radiator
Radiator Fan Timer & Condenser Fan Relays: LH Side Of Engine Compartment
Rear Defogger Relay: In Dash Relay Box
Rear Defogger Timer Circuit: In Integrated Control Unit
Rear Window Defogger: In Dash Relay Box
Relay Bracket: In Dash Relay Box
RH Brake Light Failure Sensor (1988): In RH Taillights
S4 Switch: In Center Console
Security Control Unit (L & LS only): Behind LH Side Of Rear Back Seat
Shift Control Solenoid Valve: LH Front End Of Transmission
Shift Position Console Switch: Below Console, At Base Of Shift Lever
Side Marker Relay Circuit: In Dash Relay Holder
Speed Pulser: In Gauge Assembly
Starter Relay (L & LS): In Dash Relay Box
Sunroof Motor: Rear Center Of Roof
Sunroof Relay (Close): In Dash Relay Box
Sunroof Relay (Open): In Dash Relay Box
Throttle Angle Sensor: Top Left End Of Engine
Turn Signal/Hazard Relay: In Dash Relay Box
Windshield Washer Motor: Behind RH Side Of Front Bumper, In Washer Fluid Reservoir
Windshield Wiper Motor: At RH Rear Corner Of Engine Compartment
Winter Position Switch: At Trim Panel, Below Steering Column
Wiper Control Unit: At Trim Panel, Below Steering Column
< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </>< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </>
</>Edited by: Legendary88
