Whats up guys? Im new to the forum, but I justgot my 3rd G1 Legend. It has a few bugs, I got it free from my ex. I thought this list might help some guys here. Enjoy.. 86-88 G1 Legend A - Z Component List[img]smileys/smiley8.gif[/img] A/C Compressor Clutch: Lower RH Front Corner Of Engine Compartment A/C Compressor Clutch Relay: RH Front Corner Of Engine Compartment A/C Condenser Fan Motor: RH Rear Of Radiator A/C Condenser Fan Relay: LH Side Of Engine Compartment A/C Condenser Fan Resistor: Lower RH Rear Of Radiator A/C Pressure Switch: RH Side Of Engine Compartment A/T Control Unit: Below Driver Seat, Under Panel A/T Control Unit: Under LH Front Seat Atmospheric Pressure Sensor: In Dash Relay Box Blower: Below RH Side Of Dash Blower Motor High Relay: Below RH Side Of Dash Blower Motor Relay: Below RH Side Of Dash Brake Light Switch: Top Of Brake Support Chime: In Dash Relay Box Climate Control Unit (LS): LH Side Of Engine Compartment, Behind Underhood Relay Clutch Switch: Top Of Clutch Pedal Support Coolant Temperature Sensor: LH Front Of Engine Cooling Fan Control Unit: Behind Center Of Dash, In Heater Housing Cruise Control Actuator: Lower RH Front Of Engine Compartment Cruise Control Unit: Behind LH Side Of Dash Dash Relay Holder: LH Side Under Dash Dashlight Brightness Control Unit: RH Side Of I/P Dimmer Relay: In Underhood Relay Box Evaporator Sensor: Behind RH Side Of Dash, At Evaporator Fan Control Unit: Behind LH Side Of Dash Fan Timer Unit: Under RH Front Seat Front Map Light: Top Of Headliner Fuse & Relay Holder (LS): In Dash Relay Box Horn Relay: In Dash Relay Box Information Control Unit (LS): Above Glove Box Key-Off Timer Circuit: In Integrated Control Unit LH Brake Light Failure Sensor(1988): In LH Taillights Lighting Relay: In Underhood Relay Box Lock-Up Control Solenoid Valve: LH Front Of Transmission Oil Temperature Switch: Top RH End Of Rear Valve Cover PGM-FI ECU: Under RH Front Seat PGM-FI Relay: In Dash Relay Box Power Amplifier Relay (LS only): LH Side Of Trunk Power Antenna Motor: LH Side Under Dash Power Door Lock Control Unit: Front Of LH Door, Behind Door Trim Panel Power Door Locks LH Rear Actuator: In Rear Half Of LH Door Power Door Locks RH Front Actuator: In Rear Half Of RH Front Door Power Door Locks RH Rear Actuator: In Rear Half Of RH Rear Door Power Seat Front Lift Motor: Under LH Side Of Driver Seat Power Seat Limit Switches: LH Side Of Driver Seat Power Seat Rear Lift Motor: Under RH Side Of Driver Seat Power Seat Reclining Motor: In Rear Of Driver Seat Power Seat Relay Assembly: Under Driver Seat Power Seat Sliding Motor: Under Front Seat Of Driver Seat Power Seat Switches: LH Side Of Driver Seat Power Window Control Unit: Front Of LH Door, Behind Door Trim Panel Power Window LH Front Motor: In LH Door Power Window LH Rear Motor: LH Rear Passenger Door, Behind Quarter Trim Panel Power Window Relay: In Underhood Relay Box Power Window RH Front Motor: In RH Door Power Window RH Rear Motor: In Lower Of RH Rear Door Radiator Fan Relay (L & LS): LH Side Of Engine Compartment Radiator Fan Relay (Std.): In Underhood Relay Box Radiator Fan Resistor: Lower LH Rear Of Radiator Radiator Fan Timer & Condenser Fan Relays: LH Side Of Engine Compartment Rear Defogger Relay: In Dash Relay Box Rear Defogger Timer Circuit: In Integrated Control Unit Rear Window Defogger: In Dash Relay Box Relay Bracket: In Dash Relay Box RH Brake Light Failure Sensor (1988): In RH Taillights S4 Switch: In Center Console Security Control Unit (L & LS only): Behind LH Side Of Rear Back Seat Shift Control Solenoid Valve: LH Front End Of Transmission Shift Position Console Switch: Below Console, At Base Of Shift Lever Side Marker Relay Circuit: In Dash Relay Holder Speed Pulser: In Gauge Assembly Starter Relay (L & LS): In Dash Relay Box Sunroof Motor: Rear Center Of Roof Sunroof Relay (Close): In Dash Relay Box Sunroof Relay (Open): In Dash Relay Box Throttle Angle Sensor: Top Left End Of Engine Turn Signal/Hazard Relay: In Dash Relay Box Windshield Washer Motor: Behind RH Side Of Front Bumper, In Washer Fluid Reservoir Windshield Wiper Motor: At RH Rear Corner Of Engine Compartment Winter Position Switch: At Trim Panel, Below Steering Column Wiper Control Unit: At Trim Panel, Below Steering Column < src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </>< src="http://www.google-analytics.com/urchin.js" =text/> </>< =text/> _uacct = "UA-939292-41"; urchinTracker(); </> < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </>Edited by: Legendary88 |
