Help with (# Legend
Old Jan 29, 2009 | 02:41 PM
Blade89's Avatar
My buddy gave me an 93 Legend for free, I got it and learned that it wouldn't start but it turns over. The alternator and battery have been replaced. The timing belt was replaced at 100K but now has 192K. I'm thinkin it may be the timing belt, starter, or coils. I was going to do a compression check and get an obd reader and see what that says. Any idea's on what may else be the problem?
Old Jan 29, 2009 | 05:15 PM
nopeyou hit it on the head.start with a compresion test.
if that passes then look into the distrubitor and ignition system.
if you have no fuel pressure i would suspect the main relay befor a fuel pump.
Old Feb 2, 2009 | 09:29 AM
LTVans's Avatar
sounds like the same thing mine was doing when i first got it once i choked out the system by putting my hand over the intake hose it would start right up and run sh*tty till it warmed up a little and it would start fine for the rest of the day just fine
Old Feb 7, 2009 | 01:20 AM
masumi's Avatar
have check the fuse. or maybe from the battery or maybe from sparkpulg. good luck
1994legend6spd
May 28, 2008 12:05 PM
rnr568
Feb 12, 2008 11:40 PM
