Fule Pump?
My '82 Legend, very infrequently, will turn over but not start. After it sits for a while, it will start. I am wondering if this might be an indication that the fuel pump is failing and if there is a way to diagnose the problem.
Also, I have looked at the in line manual which does not give any guidance I can find on replacing the pump. It apparently is in the fuel tank and I am wondering if this is a complicated procedure and where I could get guidance on doing it.
Thanks to all in advance!
I believe that the first thing you may want to look into is your Fuel Pump Relay..Call your local parts supply house and see if they have one for you.
klopot187
Jun 5, 2007 01:17 AM
