D4 light blinking???????
I have a 94 4 door, when ever the car is on the light on the cluster that says Drive 4keeps blinking, I dont know what it means.....any help?
Does your speedometer bounce up and down randomly as well? I was told by a Sears mechanic that the old Legend models have a defective Vehicle Speed Sensor, thus causing the blinkingD4 light and a couple other control panel anomalies. He recommended that I order the part and either replace it myself because it's simple or have someone I know that is a mechanic do it for cheap.
most of the time its a speed sender.
if you have a light that means there is a code.
go to a shop and have the transmission codes pulled.
because it could be as bad as a 2nd gear pressure switch is bad, and if you dive it it can destroy the transmission.
that D4 is serious business.
Thanks for the info, I have a 94 Legend gs, I took your advice,did what you said and now my Legend is back to where it used to be.You saved me a lot of money.
Thank you
