I have a 94 4 door, when ever the car is on the light on the cluster that says Drive 4keeps blinking, I dont know what it means.....any help? < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
Does your speedometer bounce up and down randomly as well? I was told by a Sears mechanic that the old Legend models have a defective Vehicle Speed Sensor, thus causing the blinkingD4 light and a couple other control panel anomalies. He recommended that I order the part and either replace it myself because it's simple or have someone I know that is a mechanic do it for cheap. |
I recently had the same problem. It is the speedo sensor on the transmission. Autozone has it for 150.00.
most of the time its a speed sender.
if you have a light that means there is a code. go to a shop and have the transmission codes pulled. because it could be as bad as a 2nd gear pressure switch is bad, and if you dive it it can destroy the transmission. that D4 is serious business. |
< src="http://www.google-analytics.com/urchin.js" =text/> </> Thanks for the info, I have a 94 Legend gs, I took your advice,did what you said and now my Legend is back to where it used to be.You saved me a lot of money. Thank you < =text/> _uacct = "UA-939292-41"; urchinTracker(); </> |
9 out of 10 times its the transmission sensor. If you buy the part it is located on the front of the transmission behind a cover.
