Check engine ; 7 flashes
Old Mar 24, 2013 | 09:36 PM
denism28's Avatar
Default Check engine ; 7 flashes
It is the throttle position sensor. The light goes on only when warm. Could it be soldering problems like the starting relay over the steering tube ???
Old Mar 25, 2013 | 01:47 AM
Talking Hi Member
You need to put in the year,make,model and trans and engine size for more information..Engine ..what litre?
Old Mar 26, 2013 | 07:41 PM
denism28's Avatar
Default Legend 7 flashes
Sorry; It is a Acura Legend 1990 2.7 LS sedan automatic V6 with 100000 mi . The car runs perfect even if the check engine is on .. which happens only when the motor is hot ; if the light didn't show, you would'nt know that there is a problem. The replacement part comes complete with the air v olume sensor and costs 700$ As the trouble happens only when the motor is hot I suspect a soldering problem like the main starting relay over the steering tube. I really appreciate any suggestion youy can give me. Thanks.
mattrich0988
Aug 28, 2007 07:41 AM
priority04
Jun 13, 2007 11:52 AM
Spiez
Nov 8, 2006 01:09 PM
GS-R_JHULL
Sep 3, 2006 06:45 PM
gsrgirl
Mar 14, 2005 05:22 PM
