94 Legend Intermittent Rough Idle - Shake
Old May 1, 2007 | 01:32 AM
rstep1's Avatar
This has happened about six times within the last three months, all of a sudden my car starts to idle really rough, actually starts to shake, this is when the car is at a complete stop. Normally the car runs great, no knocking, very smooth. Do the IAC valves get clogged on these cars? They control the idle. I can not pin poiint the problem , no check engine light... nothing. 98% of the time the car runs like a champ.
Old Jun 26, 2007 | 09:31 PM
ryan83189's Avatar
hey i had the same problem , i suggest fuel injector cleaner , and highly recomend using 89 octane all the time , that helped me. when this happened to me i had my lights and ac on , so i figured it was a fireing problem . i also bought a k&n airfilter and this seemed to help too. worse come to worse id just pull the handbrake and put it in neutral and feather the engine a little . if a slight force on the pedal seems to help you could just raise the idle speed a little . I hope this helps you as much as it helped me.
Old Jul 29, 2007 | 12:52 PM
Nemesis's Avatar
My engine revs once in a while with my 94, also. I'll try your advice. I only use the highest grade gas, and it didn't seem to matter if I had just had a tune up or major engine work done. This usually occurs after starting the car with mine, though. I forgot to add that it only does it while in park. Not while sitting at lights, etc.
Old Aug 2, 2007 | 09:34 PM
coopster's Avatar
My car has the same problem, I spend more time in parking lot because I can't get my car to run.
Old Aug 20, 2007 | 08:05 AM
hmmm how long has it been sence a tune up?
did the tune up include new oxygen sensors?
next time your in park and it starts acting up, try different things
like turning on your A/C, turning your wheels hard loading the
electrical system(lights,windows,etc...)
If it causes the symtom to stop then yes focus on having the idle air
controll circuit cleaned/replaced. if not them hmmm back to the basics
then.
tune up.
hose checking.
batt cables checked
chassis grounds checked.
but if your stuck in a parking lot with a crank no start situation (
kinda like vapor lock) then have that main buss relay replaced.
VinceS
Oct 23, 2012 10:30 AM
supplybfk
Oct 22, 2010 09:28 PM
dragonman
Apr 6, 2010 06:51 PM
cbads06typeS
Dec 10, 2007 02:40 AM
slange
Sep 18, 2006 11:47 AM
